1 - 13 of 13 Posts
02/20/2008: Purchased bike with Mileage at 4,605. Came with Hard Krome 3" straights; Kury Pro Hyper Charger; Power Commander III USB; Hondaline Deluxe backrest; Hondaline saddlebags.
March/April 2008 upgrades: Kury ISO grips; Tank bib; New Dunlap Tires; Hondaline Deluxe Luggage rack; Kury clock; Chrome radiator cover; Kury Chrome rear Master Cylinder cover; Kury Chrome highway peg mounts (floorboard connection) and ISO footpegs; ShowChrome Highway (engine guard) Bars for VTX1800, Kuryakyn Handlebar Control Covers
May 2008: Mileage 5,100, Changed oil (Amsoil), oil filter (Bosch 3300), & spark plugs (NGK IFR5L11); mounted new tires front & back; Fixed VTX grounds; installed new fuel pressure regulator; new Cam sensor; new hyper charger filter.
June 2008: Installed KEW-135 - Upper Triple Tree Cover Plate; BIG-1321 - Big Bike Parts Chrome Billet Front Axle Cap & axle plug; KEW-418 - Kewl Metal Front Wheel Rotor Chrome Dress Up Hubs; KUR-8260 - Kuryakyn Frame Trim; Aeromach 4" Chrome Risers.
July 2008: Installed Honda Chrome Front Fender Tip; Installed H-D Chrome fuel breather for breather hose; replaced stock horn with Solid billet Chrome Horn.
Sept 2008: Installed KY-4001 Kuryakyn Driving Light Bar with L.E.D. Turn Signals; KY-2328 Kuryakyn Universal Wiring and Relay Kit; KY-4002 Kuryakyn Front Mounting Brackets & front L.E.D Arrow-shaped Amber turn signals.
Oct 2008: Replace all brake pads.
Nov 2008: Converted the stock rear turn signals with L.E.D. run/brake/turn lights.
Winter Mods: 2008-2009 (Dec-Feb)
1. Hard Saddlebags: Purchased set of H-D Softail Fatboy Hard Saddlebags; Hard bags painted Illusion Blue; Purchased set of Edge brackets and modiified to fit the H-D saddlebags.
2. Chrome parts: Installed KY-1546 Kuryakyn Chrome Motor Mount Accents; KY-1431 Kuryakyn Turn Signal Mirrors with Flat Glass; KY-8285 Kuryakyn Driveshaft Cover; KY-8688 Kuryakyn Drive Hub Top Cover; KY-8287 Kuryakyn Swingarm Cover; Rear Ostrich Style Tuxedo Tie; Rear Hondaline Chrome Solo rack ; KY-7963 Kuryakyn Dually ISO Pegs; KY-8802 Kuryakyn Footpeg Adapters; Kewl-101 Chrome Triple Trees; Kewl-172 Memphis Shade Mount kit; Kewl-159 & Kewl-160 Chrome Fat Fork Tubes; Kewl-165 Chrome Brake Manifold cover; KY-8684 Kuryakyn Chrome Lower Fork Skins.
3. Ultimate X Seats: Apr 2009: Replaced stock seats with Ultimate X lowboy & passenger seat; Replaced stock oil dip stick with Chrome Oil Dip Stick with Temperature Guage.
4. Desmogged. May 2009.
2010 Pictures
Winter Mods: 2009-2010 (Dec-Feb)
1. Custom Paint:
All new paint work done.
2. Fuel Tank: Replaced my '03 tank (and internal fuel pump) with an '05 seemless fuel tank. Had to add an external fuel pump & fuel lines to support the '05 tank.
3. Meter Assembly: Removed the stock meter assembly from the tank and fabricated the meter area flush and installed a pop-up gas cap.
Installed the Dakota Digital MCV-7000 for instrumentation. Milage on removed odometer was 6,165 miles at conversion time.
4. Fairing/Radio: Purchased a used fairing shell on eBay, new Chrome package (speakers/windshield & trim) from Hoppe, and radio from Best Buy. Manufactured panel light trim piece and installed 3 panel lights to support the FI/Low-fuel/TEMP indicators. Installed all fairing components and wiring.
5. Wheels/tires: Replaced the stock cast wheels with Chrome RC wheels.
Darksided Rear wheel/tire with Toyo 215/45/18. Front tire ME880 150/80/17. PSI Front(40)--Rear(35)
6. Brake/Clutch lines & Throttle Cables: Replaced all stock brake and clutch lines with Spiegler's. Replaced stock throttle cables with Magnum Sterling Chromite's.
7. Handlebar Wires: Rewired all handlebar control wires internal through the handlebars. I don't think this mod was worth the time/effort. Just my opinion.
8. Exhaust: Replaced the HK 3" Big Straights with HK 2 into 1 Sideburners.
9. Air Intake: Replaced the Kury Hypercharger with the S&S Teardrop air intake.
10. Final Drive: Replaced the stock 1800 FD with a 1300 FD.
11. Shocks: Replaced the stock shocks with Progressive 430's.
12. Radiator Cowl: Replaced the grill cover with a used Bestem radiator cowl (spoiler) I purchased cheap from eBay.
13. Engine Highway Bars: Replaced old guards with National Cycle Paladin bars.
14. Rear Fender/Tail Light: Replaced the stock rear tail light assembly with a custom-made (1 of a kind) LED flush-mounted assembly ('39 Ford teardrop with Blue dot). The fender fabrication work was done to facilitate the flush mounted LED tail-light.
15. Rear Turn Signals: Converted the stock turn signals with LED run/brake/turn signal lights.
16. 2-Postition Switch: Added a 2-position switch to control power to the Radio (switch-1) and the Light bar (switch-2). The switches go through separate relay's installed.
17. Rearview Mirrors: Replaced stock mirrors with Kury Turn Signal Mirrors.
18. Risers: Replaced the 4" Aeromach's with 6" Paul Yaffe Barrel Pullbacks.
19. Floorboard Covers: Added chrome Kury flamed floorboard covers.
20. Throttle Lock: Added chrome break-away throttle lock.
Winter Mods:
2009-2010 Pictures
8)
Discussion Starter #4
July 2010: via Paul @ GatewayXtreme.
1. Final Drive:
Replaced my 1300 FD with new Chrome 1300 Final drive/Dust ring/Filler cap/Drain bolt. New FD fluid added.
2. Swing Arm: Replaced stock swing arm with Chrome swing arm & Drive shaft Bolt cover.
3. Kick Stand & bracket: Replaced stock stand/bracket with Chrome Kick stand & bracket.
4. Brake calipers: Replaced front & rear stock brake calipers with Chrome brake calipers. Brake fluid changed.
5. Radiator Fluid: Changed.
6. Fuel Filter: Changed.
7. Rear Brake Caliper Mount: Replaced stock brake mount with Chrome mount & rear brake line brackets.
8. Rear Foot Peg Mounts: Replaced stock rear mounts with Chrome rear mounts.
9. Rear Axle & Nut: Replaced stock rear axle & nut with Chrome axle & nut.
Winter Mods: 2012
Winter Mods: 2012
1. Custom Paint:
2. Front Forks:
(1) added new Progressive springs and replaced seals/oil and (2) added new lower fork ends from Kewl-Metal.
3. Rear Fender:
Removed the tail light & fabricated the tail light area flush.
4. Saddlebags:
Installed new QQ bags. Fabricated work on bags: removed QQ logo, shortened the LED area, installed Radiantz LEDs, replaced locks with Tubular Cam Locks.
5
. Saddlebag LEDs: Wired the saddlebag LEDs to operate as Run/Brake/Turn.
6. Light Bar:
Replaced old light bar with a new National Cycle light bar.
7. License Plate:
Added new license plate mount with LED brake/run lights.
8. Exhaust:
Added new BUB Jug Huggers.
9. Chrome Engine Covers:
Added new Kury chrome engine covers.
10. Brakes/Oil:
Bled brake system and replaced oil (Amsoil) & filter.
Discussion Starter #12
The Oil & Filter has/is changed every year using Amsoil.
The Current mileage is 10,432.
Pictures attached are from the last build.
Discussion Starter #13
2013 rebuild pictures.
1 - 13 of 13 Posts
