Visually inspect the fuel lines, including the interior - often the rubber cracks can't be seen from the outside.
You don't mention the bike's history - that leaves a lot to consider.
Check the air filter - make sure it's clean (and lubed if reusable).
Check the overflow tube behind the air filter assembly too.
There's a small fuel filter in the hose @ the carb - check that.
Consider running a stabilizer if the carb is gunked up.
Check the plugs.
If it's a CA bike, is it desmogged?
This may or may not be good advice - just going off of my COVID rebuild learning experience with a 1300.
I'm sure others will be on-board to correct and to add to.
Enjoy the ride.
Check the plugs.
Enjoy the ride.
