Will handlebars from a vtx 1300r work on a 1300c without changing the cables and brake lines?
Yes, if you stay with low risers. It will help if you re-route the cables behind the triple tree and re-route the brake hose. Factory cables from the R or S are cheap and not hard to change.
I used 4.5" risers & S/R bars & cables...They are 2" longer than the C cables...Cheap & easy to replace.
