I have a 2003 VTX 1300 retro and would like to go from the stock headlight to a LED but I am not sure what is the best way to go. Any ideas would be appreciated. Thanks
The H4 Led which has been around for a few years with mixed results
on the beam pattern. I probably installed 3 different versions of H4 Led.
Now the "Daymaker" style headlight has become popular.
Better beam pattern.
At the top of the page is a "Search Community", type "Daymaker" or "H4 led"
and read. Daymaker bracket fit HD products only. 2017 things started to happen.
Danow here on the forum made his own bracket. I made own bracket in 2018.
Both DIY bracket versions are in the forum. I can adjust my height setting.
Some brackets required shims to aim the headlight.
Some brackets were 3D printed.
Then someone came out with a bracket that would mate to VTX headlight rim bracket.
Others will chime in.
I appreciate your time and input
Check out VTXdaymaker.com
Great product, good support and it’s adjustable.
Examine the beam patterns carefully.
They have several different style lights.
Some better than others.
Reactions: rangers4u
I just bought one. It's just been shipped. If you go to the website you will find maybe a half dozen style & brightness options, and I believe they all come with the newer adjustable bracket. Some are available with a full time daytime running halo. I chose the B2 model, for $160.
