I just want to preference this by saying that the only work that had been done recently was an oil change. Here is a list of everything aftermarket mechanical on the bike:
Cobra Exhaust
Pear Valve removed w/block off plates
Kuryakin Hypercharger intake
Amsoil
My problem is that my '05' 1800N is idling rough and has no power at low and high speeds... FML!!! :cus:
This is how is started... about 100 miles or more after the oil change I was riding into work and near the end of the 10 mile ride it began to run like it had no power on acceleration. At the end of the day it fired right up and rode home with no problems. A couple days later I rode again after a couple miles the problem began again so I parked it for about an hour and when I started it up again the problem began immediately. From then on the problem is constant.
Here are the symptoms my girl has:
- #1 Cylinder’s exhaust is colder than #2 when first started and for awhile after start while idling.
- Rough Idle (Sounds like its missing but no knocking)
- Strong Fuel smell when running
- Reduced power on acceleration and normal speed (Went on short run after replacing plugs and found that I had to hold the throttle open more than normal to keep my speed up)
I have consulted Clymers and this is what I have done so far: :tools:
- Ensured oil level is correct
- replaced the plugs (old ones not fouled but some carbon buildup on rim)
- checked to make sure there is spark to each plug by grounding an extra plug to the block while running
- unplugged one plug wire at a time and found out that when unplugged the #1 right plug causes rougher idle, #1 left plug does not cause a rougher idle, and both #2 plugs cause a rougher idle. This leads me to believe that while I am able to prove that there is spark going to all the plugs something is wrong with the #1 left plug.
I have not checked the Timing as Clymers suggests because I'm not confident that could be the issue. Also I haven't checked valve pressure cause I don't have the gauge to check it.
My next coarse of action is to take off the tank and test the coils but before I do that I want to talk with the VTXOA community and see what ya'll have to say. After reading some other posts I feel that it may be the FPR or the fuel filter or a number of other issues. That is what I would like to hear from the experts... cause I'm just hitting my head against the wall here!!! :banghead: :dontknow:
Any help you guys can give will be greatly appreciated!!!
Cobra Exhaust
Amsoil
