1 - 3 of 3 Posts
The bolt that holds the lower shock on broke off left side is the stud that sticks out of the rear end pressed in or does it screw out.If i had the stud out it would be easer to work on.
From what I remember, the top mounts onto a stud that is screwed in to the fender strut. The bottom of the right shock is held on with a bolt that screws into the swingarm. The final drive side has a stud that screws into the final drive
broke
Thanks I got the broken bolt out used sharp punch backed it out till I could get a grip on bolt.I have a licence plate mounted to the lower shock bolt if it breaks again I will have to try something different.
1 - 3 of 3 Posts
