My 2008 1800t has been running slightly off, a little less power and a little less fuel economy. I regularly got 37-38 mpg now I get about 33. My bike is preformance wise mostly stock except for pair valve removal and desmog Here is a chronological, more or less, list of what I have done to track down the problem.
New air filter and cleaned the plugs
I removed the cobra fuel programmer( AT Black)
Added Sea Foam to 2 tanks of gas
Checked for vacuum leaks
Replaced the plugs with NGK IFR5L11
Ran another tank of Sea Foam
With the ngk plugs I could tell that the right rear plug is running too rich
Trimmed the plug wire and made sure it was seated well
I swapped coils front to back and the problem didnt move, still right rear plug too rich
Checked grounds and made sure the connections to the coils were tight
I ordered a new Factory plug wire assembly
The battery load test correctly and the connections are tight and the bike starts easily
today I pulled the leads off the injectors and checked the ohms, they are about the same. I am out of ideas the right rear plug is always darker than the other 3
A person on this board (I Think) once said "These bikes approaching 15 years old, there are no new problems just problems new to you(me) Any help will be appreciated
