I have a 2008 VTX 1300 R
Whether choked or not, it sputters when starting up (regardless of temp), runs fine after 2-3 miles. If I stop on a ride to take a break, and fire it back up after a 10-15 min break, it sputters and dies, then runs fine after a minute or so.
I have Cobra Classic slash cuts and a K&N filter (just filter, no "kit"). No other modifications.
Called my local dealer as bike is still under warranty, and he said Carb issues do not fall under the original 1 year warranty. He suggested dumping in some Marvel Mystery oil and 93 octane fuel. No luck, did not change a thing.
Bike ran fine all the way from last June to this past February (when I had to use a bit more choke in the morning).
Have read in forums that an A/F screw adjustment is needed, but I am new to this.
How close are the recommended settings of "2 1/2 turns" given my setup?
Have pulled the plugs and they are not totally shot, but a bit fouled. What is a good cleaning method? Or should I just replace them? If replacing, should I go stock, (NGK-DCPR 6 E) or is there a better brand or type? Please provide a link for them if different.
Regarding A/F setting, if environment makes a difference, I live in Florida and weather is generally mild year round. 80% of my driving is city streets.
If you have any pictures showing locations of the screw, please fwd a link.
If anyone out there has been through this or a similar situation and can provide a bit of info, I would greatly appreciate it.
