Guest
'03 VTX 1800- When I'm cruising in 4th or 5th gear and my RPMs have come down, when I throttle up to get speed, sometimes my bike stalls for just a split second. It's a good jolt! The F1 light comes on for 2-3 seconds then everything is normal again until I recreate the situation. I changed some ugly spark plugs and added injector cleaner, but didn't show much improvement. Any advice? and how much $$$??? Thanks a bunch :yikes:
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
If the FI light came on, it should have stored a trouble code. Turn the key to on and see if the FI light blinks. Count the blinks and pauses.
