1 - 3 of 3 Posts
Sometimes I get a single backfire slowing down from cruising speed. Iwould like to fix it myself but am out of ideas. I have done the following:
1) Put Roadhouse classics on and had Dynojet kit installed and Dyno'd
2) Reinstalled Roadhouse and put new gaskets(again)
3) Charged the battery and it went completely away for a week or two.
4) Removed pair valve
5) Removed packings in Roadhouse(better but pop)
6) Ran 89 octane and very infrequent pop(better yet)
7) Put K&N filter on(worse yet w/hesitation in low gears and some pop)
Pop
When you changed exhaust and rejetted, did you still have the stock air box and filter? If so, when you went to the K&N, you may be too lean now.
I know this sounds stupid, but mine did the same thing. It was a loose battery connection, and from what i hear, its pretty common. Once I tightened the cable, I got no more pops. Just a thought.
1 - 3 of 3 Posts
