1 - 2 of 2 Posts
It's under the carb. In the back.
Take the tank off, remove airbox, loosen the hose clamp on rubber boot, pull the carb off of the boot, and turn towards you a little. You should see it then. When putting the carb back on the rubber boot, make sure you align the notch in the boot with the notch on the carb.
1 - 2 of 2 Posts
