1 - 3 of 3 Posts
I just got done with the ground mod, fuel disconnect, coolant change and valve adjustment. I've spent more time on top of, underneath and around my bike than I ever have.
When putting things back together I noticed that the fuel tank breather hose ran from the tank to a T connection and then it splits off in two different directions. The front end split dissapears insided the frame and the other end just heads south with no connection. Did I disconnect something or should this breather hose just hang loose, like a coolant tank breather hose? :roll:
Spaggs :blkc:
Mad Hatter
Like Said, U are fine.. It is a Venting Hose in front of the swing arm..
1 - 3 of 3 Posts
