Which system would you buy?
  • Hard Krome Big 3's
    Votes: 0 0.0%
  • Vance & Hines Big Shots
    Votes: 0 0.0%
1 - 10 of 10 Posts
Hey guys I need your opinions. My 1800R came with the HK 3's and it sure has that poppy, pingy, air sucking sound that I don't care for. I've just lived with it for the past 4K miles but I am considering getting a different system. Do the VH Big Shots sound deeper and less of that sound?? Or is it just part of the 1800 sound? Let me know what you think! :popcorn:
have an 03 C I put HC 3" on, bought used came with Mike's resonators. On my 05 R I got some VH Bigshots with the quiet baffles. I really like the sound of the VH over the HC. I know on Utube they have the sounds of both but the sound is not like hearing them live.
Sound is very subjective. What I may like, you may hate. Now you've spent $500 or more on a system that you can't stand the sound of. I've heard this many times over the years on this board.
"I just purchased an exhaust from recommendations from this board and they sound horrible. What do I do now?"
Best thing to do is find your state board from this list; http://www.vtxoa.com/forums/forumdis...aysprune=&f=75
Then find out when & where fellow VTXOA members are getting together and go introduce yourself and have a listen
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
That sound might be the PAIR valve system working...Most guys remove that crap and chuck it in the corner when swapping pipes...It's just an emissions system that injects fresh air into the exhaust ports on top of each head..A set of $20 block-off plates and an hour or so turning some wrenches will improve the exhaust sound a bazillion percent...
Discussion Starter #7
Yeah its a tricky one. I went from a Yamaha Road Star Warrior to a VTX and I miss that sound. I think i will look into blocking it off though.
potato / potato sound
Mike hit on the head:yikes: , if you think any pipes you buy will make this great bike sound like a old harley:doorag: , not ,, will not happen,, i tried everything ,it is all about the crank pins ,,harley and most other bikes ride on a single crank pin ,meaning the rods are on the same crank pin ,(side by side) both at top at the same time ,honda:confused: they went for a better system ,but no potato potato ,:shock::dontknow:
Discussion Starter #9
Hey i just plugged the pair valve from the airbox and I was surprised at the difference it made! The CLAPPING sound pops are gone and it sounds much better. I know it will never be a harley and that's just fine with me. I'm gonna keep the HK's. Thanks for the input! :bowdown:
Vance & Hines plus desmog. Then you get the true 100 hp Honda V-Twin sound !:mrgreen:
1 - 10 of 10 Posts
