I found my problem, well I think im on the right track after reading a whole bunch of posts.
I changed my oil 3 days ago switched to spectro 4 full syn 10W40. I found a couple of problems that I did not realize.
1- Spectro you get more oil per bottle 1.056 quarts or 1 liter
2- If i check my oil on my lift it reads different than on the ground held as close to level as possible.
When re-adding oil I put in the first 3 and most of the 4th as normal without realizing the extra oil per bottle. It did not read full yet on the lift after idle and a 5 minute cool, strange I thought but i added the last what i thought would of been 2-3 ounces to the oil and it was fine.
Yesterday at a light I noticed a ticking like a spark plug wire ticking if it were grounding out from the right left spark plug cover area on the jug.
I read where to much oil may cause this noise also so i am starting there to see if that gets rid of it. I also turned muy idle up just a bit it was a little low.
I had 10 ounces to much oil in her for the past 3 days and I am in hope that this will solve the stoped idle ticking noise thats drivin me nuts.
will let you know.
will let you know.
