Guest
·what is the proper way to trailer a bike? it will most likely be on a uhaul open trailer. pics are appreciated.
thanks
Mike B
thanks
Mike B
Blade1 said:what is the proper way to trailer a bike? it will most likely be on a uhaul open trailer. pics are appreciated.
thanks
Mike B
thanks
Mike B
I have a 12' trailer with a attached rear gate/ramp, but the angle seems a lot steeper than your ramps. I haven't put my bike on it yet, and I was wondering if I should ride it up, or walk it up (with the engine running and using 1st gear to help pull it up.) Frankly, the angle of the gate/ramp seems to be more than I want to ride up, and I don't want to drag bottom with me on the bike.X-Cessor said:When I ride it up, the wheel chock hold the bike perfectly. I can tie down one side at a time and the bike remains in place. The same thing when disconnecting it. I can completely release one side and the bike will not lundge the opposite way.
Then I can back down the bike by my self.
The two outside ramps are for my me placement only, and the center ramp holds tha bike.
Hope this helps you.
Kenny
The seat is also made by Corbin.smokey2255 said:X-Cessor
Kenny that is one sweet ride. Love the beattle bags and that seat. Where did you get that seat. I assume its all custom. I know that these questions are gonna cost me some money but I love the looks of it. Is it as comfortable as it looks. Man I got a new wish list going on now.
I ride up my ramp. The center ramp is the bike ramp and the 2 outside ramps are for my fett to ballance the bike.KenzX said:I have a 12' trailer with a attached rear gate/ramp, but the angle seems a lot steeper than your ramps. I haven't put my bike on it yet, and I was wondering if I should ride it up, or walk it up (with the engine running and using 1st gear to help pull it up.) Frankly, the angle of the gate/ramp seems to be more than I want to ride up, and I don't want to drag bottom with me on the bike.X-Cessor said:When I ride it up, the wheel chock hold the bike perfectly. I can tie down one side at a time and the bike remains in place. The same thing when disconnecting it. I can completely release one side and the bike will not lundge the opposite way.
Kenny
Do I understand you correctly that you ride up your ramp?
