I installed my Hypercharger last night, install was real easy, did the de-smog and removal of seconday air sytem (thanks Bare and Biglry), the problem is that the butterlies on the front of the Hypercharger flutter, or pulsate rapidly, are they supposed to be smooth or is the flutter normal. They flutter at all RPM levels, the only thing that comes to mind is maybe I need a clamp on the vacuum line at the motor? Any help out there?
Mine does the same thing and I put a clamp on the vacuum line, so I am assuming it is suppose to do that.
hypercharger
Yes sir it is suposed to do that... you have 2 pistons the size of coffee cans going up and down creating that vacuum pulse. nothing is wrong
thank you for the reply, I thought that was the case.
