I had another Doc in 1300 regarding ICM wiring. Found another early wire breakage on a 1300.
Mark4of5 was pulling pins out to add a Tach wire to 1800.
Mark provided text and pix. This fits both 1300+1800.
Discussion Starter #2
Another PDF covering ICM broken wires and several ways to skin a cat.
Discussion Starter #4
I followed a link, Grunt dog of the VTXcafe said this.
I used a small cotter pin bent open ,, slide it in between the plastic housing and connector depressing a tab while
applying some force to the face of the connector moving it out of the housing
previous experiences with similar harness pins helps make this a pretty simple task ,,,
there is always a way to release connectors from housings
there was a 1/4 inch of wire still well crimped , bared some of the mating green wire and soldered it up well
pre-tinning each side before mating together
