Status
Not open for further replies.
1 - 20 of 235 Posts
I've been contacted by the NHTSA, and discussed the flange bearing issue with them. They have requested our members provide a report of problems. If you have had a flange bearing failure, please take a minute to post here.
In addition, you should browse the following link, and file a report of the failure with the NHTSA:
http://www-odi.nhtsa.dot.gov/ivoq/
Please limit responses to your personal experience. Chatter or responses which do not contain reports of failure will be summarily deleted. Please stick with facts only. No editorializing of any kind.
If you have had a bearing failure in the final driven flange assembly,
please take a few minutes and post the following information:
Approximate date of failure: (when did this happen?)
Year of Manufacture:
Model: (which model you have)
Bearing Condition: (how did you determine bearing was bad - was it rough? come apart?)
Accident : (did it result in any sort of an accident?)
How fixed: (Dealer? Bearing shop? Was it covered under warranty?)
Additional remarks: (any other pertinent information)
Discussion Starter #2
Approximate date of failure: April, 2002
Year of Manufacture: 2002
Model: VTX1800C
Bearing Condition: Bearings was rough and chattered when turned.
Accident : None
How fixed: Entire flange assembly was replaced by dealer (Plano Honda) under warranty.
Additional remarks: Discovered while replacing worn tire.
Approximate date of failure: October 2004
Year of Manufacture: 2003
Model: 1800C
Bearing Condition: Removed rear wheel to install aftermarket wheel. Bearing was shot.
Accident : No
How fixed: Dealer - purchased new bearing
Additional remarks: Bike was brand new - never ridden when we discovered the bearing was shot.
failed March 2004
2003 VTX1800C
found while replacing rear tire,inside bearing coming apart
no accident
replaced under waranty
L
Guest
Approximate date of failure: July 2002 and September 2004
Model: 1800R
Bearing Condition: Rough and chattering when turned.
Accident : No
How fixed: Replaced by dealer under warranty
Additional remarks: Bad bearing found when replacing tire both times.
Approximate date of failure: July 2003
Model: VTX1800C
Bearing Condition: Bearings was rough and made a grinding sound.
Accident : None
How fixed: All bearings in rear assy. were replaced by dealer (Woods Honda) under warranty.
Additional remarks: Discovered while riding approx 100 miles from home.
Model: VTX1800R
Bearing Condition: Bearings turned with dificulty and made a grinding sound.
Accident : None
How fixed: All bearings in rear assy. were replaced by dealer (Macomb Cycle in Mt.Clemens, MI) under warranty.
Additional remarks: Discovered during 8,000 miles rear tire replacement.
bearing Failer
Approximate date of Failure: Unknown, checked because of warnings on this board.
Model: VTX 1800R
Bearing Condition: Turned Rough & Chattering when rotated. Upon removal of Final Drive Flange found Metal shavings in grease.
Accident: None
How Fixed: Ordered new Flange Drive from dealer, with orders to check before shipment. I will be sending old one with metal shavings to NHTSA. Dealer was nice and gave 10% discount total cost to date $179.51
Addition Remarks: See photos at :
http://bigbikeriders.com/photopost/data ... gs-med.JPG
http://bigbikeriders.com/photopost/data ... ng-med.JPG
I would not have caught this had it not been for this site. My new tires had been installed and the mechanic must not have checked the bearings. I have only a few thousand miles on tires.
I filed my complaint and have been contacted by NHTSA.
PLEASE EVERYONE THAT HAS HAD A PROBLEM DO THE SAME.
Approximate date of failure: 2/03
Model: 1800R
Bearing Condition: Fell apart
Accident : No
How fixed: Tapper Warranty probably but fixed locally
Additional remarks:
Flange
2002 VTXc
Aprox failure date 7/03
Aprox 14,000 miles
Found replacing tire
Bearing races intact cages broken ,seal out
No accident
Bought and installed new flange assy.
APPROXIMATE DATE OF FAILURE: FOUND 3/10/05
YEAR OF MANUFACTURE: 2003
MODEL: VTX1800C
MILES: 6,700
BEARING CONDITION: TOTALY DISTROYED
ACCIDENT: NONE
HOW FIXED: DEALER (XTREME POWER SPORTS) TAMPA FL. WARRANTY
REPLACED 7-PARTS HUB,BEARINGS,AXIAL, ECT.
ADDITIONAL REMARKS: THIS FLANGE BEARING MUST HAVE BAD FROM THE GET-GO THE HUB WAS TOTALY EAT-UP WITH DEEP GROOVES (THREE) ALSO AXIAL.
W
Guest
Approximate date of failure: 5/4/04
VTX 1300s
2003
Miles: 19000
Bearing Condition: Totaly Distroyed
Accident: None
Found during tire replacement
Replaced myself
Flange bearing failure
Approximate date of failure: Feb 10 2005
Year of Manufacture:2002
Model: 1800C
Bearing Condition: Bearing was coming apart...alerted by grinding noise
Accident :None
How fixed:Out of pocket expense...new bearings installed by local dealer
Additional remarks: Upon discovery of failed bearing, all wheel bearings were replaced
Bad New Flange Bearing
Approximate Date: March 29th 2005
Year Man. : 2005
Model : New Final Drive Flange
Bearing Con.: Looked Great but had a tic tic feel when rotated. Just the inside bearing.
Accident : None
How fixed : Returned to dealer. They are ordering a new one.
Additional Remarks : I picked this up at Dealer. They didn't want to open it all the way just a small tear in plastic. It wasn't until I started to install it and made sure to rotate bearings individually that I felt the ticking of the inside bearing.
:evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
IT HAD TO BE ROTATED A FEW TURNS SOMETIMES TO START, BUT ONCE IT STARTED IT WOULD GET WORSE. :evil: :evil:
:evil: BUYERS OF NEW DRIVE FLANGES CHECK THEM THOROURGHLY. :twisted:
2002 C
Found May 2004.
Replacing second rear tire at 17,600 miles. Found rough bearing, checked further and bearing cage was in pieces.
Replaced myself with double sealed bearings. Flange was OK.
No accident.
Steve
Date Problem Found: 4/7/05
Year of MFG: 2001
Model: VTX1800C
Bearing Condition: Rough(Found during routine maint.) Cage holding ball bearings in the race was in several pieces. Pieces of the cage in both bearings.
Accident: No
How Fixed: Fixed at my expense, bike out of warranty.
Date problem found: July, 2005
Year manufactured: 2001
Model: 1800c
Bearing condition: Discovered the problem Because of Noise and vibration while driving. Bearings were fried.
Accident: No
How fixed: Dealer replaced all bearings and also rear wheel( Damaged by bearings going bad).
Additional remarks: Paid for all this out of pocket. And before knowing about this site and all the problems with these bearings. My Dealership knows nothing about this problem and I wonder if the new bearings put in will go bad or are already bad. I am worried.
Date of Failure: April 13th 2005
Year of Manufacture: 2004
Model: 1300C
Bearing Condition: Very rough - chatters, tight.
Accident: No
How fixed: Bearings replaced at my cost. Bike out of warranty.
Additional remarks: Discovered when wheel was removed to replac worn tire. 11500 miles.
Bad Flange Bearing
:D Thanks to this site and Bareasse's excellent tire changing instructions I found my bearing to be bad also. :evil: Cage was in several pieces and bearing was very rough. Much more would of caused damage to the wheel.
2002 1800c
Date failure found, 22 April 2005
Mileage 26,400
Found while changing tire
Final drive bearings
Approximate date of failure: April 2004
Model: VTX 1800R
Bearing Condition: Outer bearing was rough when turned with fingers
Accident: None
How Fixed: Dealer replaced entire flange assembly under warranty
Discovered while replacing rear tire
1 - 20 of 235 Posts
Status
