just recieved my chrome V style radiator cover,in the directions it mentions installing 2 upper and 2 lower rubber pieces,other than the stock grommets that holds the radiator on is all I could see .also had to do some filing
I just installed the same one myself. I think what they are talking about is you should have received 4 little rubber foam pieces with peel off tape on them. Thwey mount 2 above the grill section and 2 below on each corerner of the grill section. They mount on the inside of the cover to act as a buffer between the radiator and the cover. Hope this helps. :)
radiator cover
i didn't get anything other than te radiator i'll call hal
it does
dur went back to the package and their they were,put them on but i am also going for some spacers and longers bolts,don't like the tight fit aroung the radiator hose
