1 - 3 of 3 Posts
Does anybody have an easy way to install the Fork Flames made by Kewlmetal on the retro model? Thanks much!
Remove the fender bracket first, then attach the fork guard and reinstall. Trying to get the nut and bolt in is almost impossible. Found by removing the fender bracket I was able to install both in less than 20 minutes. Good Luck!!
I know you said Retro, but I resorted to some general purpose
cement under the bolt head to keep it from pushing out.
Kinda simulated a stud, which made it a lot easier.
Used blue loctite on the threads.
1 - 3 of 3 Posts
