I am having trouble with both signals not working sometimes.
Turning on or signaling, nothing happens then poof the signal starts flashing. happens with both.
What to do
Spray cleaner into the switch. Change the flasher. Been there don that.
So, you have an 2006 "N".. clean the switch.. .. you have electronic turn signals... not the older flasher type.. 04 backwards to 02....
bulb sockets... bad bulbs.... if one bulb in the front go bad... problems... as the electronics... gives the single filament bulb a low voltage for running light and full voltage for turn signal...
I would disassemble and clean the switch. Spraying stuff into it MAY work or awhile. But, the problem will return.
