I put on some clear alternative turn signal lenses and turned on the blinkers to check out the brightness compared to stock and noticed something weird. When I put my right turn signal on, it flashes fine front and rear, but the left (opposite) front flashes at the same time only dimmer. Same thing when I use the other directional. It is the fronts only. I put the stock bulbs back in even though I knew that a bulb shouldn't cause this and the same thing happens with the stock. I never noticed this before I changed the bulbs but I also never looked for it either. Is this normal? I haven't made any electrical mods to the bike.
