1 - 12 of 12 Posts
is the bosch 3323 for the 1300 also :wink: and what weight of oil do you use? thanks Dan
filter
Dan, Yes 3323 is what jon has me using.
Just jumped in incase you could not wait for sleepy jon to wake up. :lol:
tubbythetuba said:
I'm using a 3300.....It's a little shorter.
Personally I use the longer one. 8)
More filtration for the same price. :)
Why- what were you thinking?
Yep, both the 3300 and 3323 will work just fine. Like Sam and Steve said, the 3323 is longer and has more filtration :wink:
Steve, I was a little sleepy since I don't get home till about midnight and I'm sicker than shiite right now. I'm trying to get well enought to ride all day Saturday :wink:
Why- what were you thinking?[/quote]
Not thinking....some fly-by-nite wrench cranker named Jan, or somthing like that, mentioned that it would fit.... :lol: :p
Can't use a filter wrench on the 3323 without removing the coolant reservoir (for those who are torque-spec addicts) - not sure about the 3300. I hand tightened the 3323 down - hopefully I can get that sucker off when it's time to change it! :lol: :lol: :lol:
I guess I can always use the "screw-driver" trick to get it off. 8)
Dave~
Make sure there is only ONE gasket. Turn filter on till gasket just starts to rub then turn another quarter turn- fill with oil- start engine. Always check for leaks- RIDE!
DOH!!! :x I tightened it way too much than! Gonna hafta He-man that sucker off when it comes time. No leaks though, so that's good. :lol:
Dave~
pilkedw said:
jon now what about the second half of the question
10/40 Amsoil Motorcycle specific oil, it's called MCF :wink: I have some in quarts or gallon jugs now 8)
1 - 12 of 12 Posts
