1 - 9 of 9 Posts
How often do you guys clean your filter? I have about 4k on mine and I am thinking of pulling it. The only reason I say "thinking" is because I have the ProHyper and those little bolts are pieces of sheeiiite. I felt a few that seemed like they were stripping under the allen wrench pressure when I installed it, so I am hesitant to take it off again. I wonder if I could buy new ones......
When I went with the Thunder tear drop I called Thunder MFG and ordered a 2nd filter, they did mention I should need a 2nd, I said I know bt I wanted a second to keep ready and clean just to swap back and forth
I switch mine every 2000 miles or so thats usually every 4 - 6 weeks
of riding
Roger
You clean it with K&N cleaner and oil it with K&N oil. Not being a smartass, that's actually what you use. I hear they have an aerosol or spray oil now, which would be much better than the previous bottle of liquid.
1 - 9 of 9 Posts
