"Rejet"? NO.. you will NOT have to change jet sizes.KDKing said:I need to know if I will need to rejet if I replace the OEM air filter to a K&N. I am running the stock pipes and stock set-up.
Any input would be appreciated.
Thanks.
Cheers!
Does re-jetting usually involve replacing the jet kit or can the stock be adjusted accordingly?poolmaster79 said:You probably don't have to, but I did. I put on the Dynojet stage II kit after intalling the K&N filter. I had a noticable difference in pickup and acceleration and no decrease in fuel mileage. Much better start up and nearly no warm up time.
