1 - 10 of 10 Posts
Does anyone know what the bulb number or part number is for the Kuryakan Silver Bullet Lights. One of mine has blown out and I need to see if I can just get one at a local store or if it has to be ordered.
I don't have the Kury light but while looking for a replacement for my Show Chrome (Big Bike Parts) marker lights (which look very similar) this morning, I found that it was an MR16 halogen lamp - originally used for projectors but now more commonly found in accent and spot lighting. Here's the URL for more than you'd ever wanna know about these lamps:
http://www.lrc.rpi.edu/programs/nlpip/lightingAnswers/mr16/abstract.asp
Typically, these are 12 volt, wattages at 20, 35, and 50. Bases are 2-pin. Pay attention to the beam spreads, ie: mine are 38 degree.
I've seen these in Lowe's too.
Of course, if the Kury lights aren't like this, I'm babbling on ........
:roll:
Discussion Starter · #9 ·
Wow, that really is more than I would ever need to know. (HA,HA) that article goes on forever. Thanks for the info, I think this will help out a bunch, I am going to go to lowes today and check it out. If I can't find it then I will order from Kury... Thanks for taking the time to help a brother out.
One thing you might want to check is the connections. I was sure I had a bulb blown in mine and started taking it apart. When I got it out it looked good so I tried it one more time before buying a new one and it worked fine. Only thing I can figure, it was caused by vibration.
Jeff
1 - 10 of 10 Posts
