raging56, did installing the load equalizer resolve the problem with the running lights?? I installed the kury 2372 lights and planned to use the low level for running lights and the bright circuit for turn signals.
I connected both low circuits to the original license plate light wire (which is used for a LED side mount light now), the bright circuit to the respective turn signal wires and the ground to the bikes green wire. All lights seemed to function properly until I ran the bike.
At idle, all lights work right...but as soon as I touch the throttle, the kuryakyn running lights turn off...well actually the left light turns off, and the right one flickers!
At first I thought that I was overloading the bikes circuit by running both kury's and the license plate light on the same circuit, but the licence plate light is rock solid! Maybe the bike is sending too much power to the kuryakyn low level circuit once the rpms are increased???
For now I have disconnected the low level circuit and only use the turn signal on the high level circuit...but I would REALLY like to use the dual circuit lights as running/turn!
Oh...and the turn signals already flash at the normal rate because I use the HD flasher unit...it's just the running lights that are giving me grief.
