Is anyone using this?
I have mine wired up with a direct fused line to the battery to a relay connected to the light circuit to turn the light bar off when starting the bike. I also have 2 silver bullets on the rear acting as run, brake, and turn signals - no other lights or accessories that draw juice.
Had the bike out and did about 120 miles total in a couple days - tonight the battery light went on indicating it was not charging? these are 35W lights with a small LED array for turn signals. Could this be draining my battery faster than the alternator can charge?
If you are using this - are you experiencing this problem and if so how did you wire it to avoid the problem. My desire is to have them on all the time for safety.
Looks like the one I have on mine. It took me a while to get the led signals wired in right but thats the only problem I had. They were not bright enough by themselves so i left the factory on with them. I used the relay kit also. I run them just about all the time. I installed them about 6 or 8 months ago and all is working well for me
Jeff
I used the kury harness also...no problems...I also hooked my lightbar up so it only works on high beam....I found myself blinding people with it on all the time
I also found that the LED strip is not bright enough so I used the Pro-One mirrors that look just like the Rivco on HDL and people have no problems seeing me now :D
