Hi
2003 vtx 1800c 17000 miles
Had a leak from waterpump.
I installed a oem waterpump, with newo ring, gasket, and oem radiator cap.
I did have a leak at the metal upper water pipe with the new oem gasket when I ran the engine to test for leaks.
I didn't drain the new coolant i pulled off the upper water pipe and swapped to the old computer gasket and refilled what coolant i lost.
I started bike blipped the throttle to burp system, added some more coolant, put the new radiator cap on and ran bike in neutral till fan came on.
I shut bike off and noticed coolant on the back of the front jug dripping from somewhere above the idle adjuster.
Anyone run into this?
There's a 2" or so hose going into the back of the front jug and may be the culprit.
Any help appreciated.
