If i put LED turn signals on my bike,do i need a load equalizer?
Illusion Blue said:If i put LED turn signals on my bike,do i need a load equalizer?
Most likely yes, unless you add LOTS of LEDs.thegreenvalley said:I'd like to add to this question. If I change out all the standard bulbs to led, do I still need the load equalizer?
So what should i ask for exactly when i go over there?pwillyams said:some of the benefits used to sell LED's, less current draw, is negated by the load equalizer. You are just putting the heat into the resistor instead of the bulb. You can get a load independent, electronic, flasher at auto zone for 12 bucks.
