MBW VTX 1300 C rear led turn signals
I bought and installed the same MBW LED rear fender turn signal arrays that MikeG1 has this winter.....I think they are super bright, easy to see in the daylight....BUT.....
I live in Idaho, which is sort of "Alabama of the Northwest"...this state doesn't require a helmet (if over 18), doesn't require turn signals, only one mirror and motorcycle do not require any safety checks, even when you license them.......
BUT back to these cool turn signals....when I bought my 2007 VTX 1300 C last year...which is white also....the previous owner has taken a dremel tool to the complete rear fender mount for the stock turn singal and license plate assembly.....everything was gone, which in this state is ok, since your arms are the only required signals needed anyways....
I did use the my arms last summer, but I'm old and lazy and retired...so I wanted to find a way to install some signals without drilling holes in the rear fender for normal signals....then I saw these puppies...WELL...
The hard work was done...cutting all the stock hardware and mounts from the underside of the rear fender without screwing up the paint, etc...so I sprung for these MBW strip LED units...manufactured specifically for the VTX 1300 C fender...a perfect fit I might add...
I ordered the clear with amber LEDs, because I've had the smoke lens stuff..and they are not very bright....if someone wants the amber LEDs to be seen, why in the world would you put sunglasses over the bulbs?? Looks cool, I guess..
mine have 60 LEDs on each side of the fender, about 1mm apart and they are bright and easy to see...they wrap around each side of the fender line to be seen from the side and the rear....
go to MBW.com website or the radiantz.com website and check em out..if you need more information about them ...email me....Steve
