1 - 9 of 9 Posts
Little reminder, did you checked your…
…Tire pressure today, this week – this YEAR???????
Precise tire pressure is important for your safety, lifetime of the tire and fuel consumption.
The exact pressure is on the sidewall of your tire. Some riders prefer more pressure on the C- Models because of “cupping”. I lead the cupping back to the weak fork springs.
Anyway I would not recommend going higher then the manufacturer state on the tire. With a too high pressure you will loose traction.
You should check your tire periodically for objects such as bolds, nails or other bad things.
Have a good and safe ride…
Fozz said:
Black Mtn Man said:
Good reminder.....and don't forget to check the nuts & bolts too
Great reminder. I try to check my nuts every morning, whether I ride or not.
Fozz
If my wife is in the mood she will check them for me. :D :D :D
I put some of those valve stem caps that have the green pop up thing in them that let you know when your at 32psi, so you can tell at a glance, they seem to work
you put 'em on yer nuts? :roll:
1 - 9 of 9 Posts
