There aren't any front end lowering kits. It is too dangerous to lower the front end on the X. The lean angle is extremely low as it is and by lowering you will drag the frame or exhaust first and you will take a trip over the "High-side" and into an ER. Lowering the rear is OK and you do this by having you stock shocks cut or buying shorter shocks. 12.25inches is stock for rear shocks. 8)
Here are past threads asking same.
http://www.vtxoa.com/forums/viewtopic.p ... +front+end
Welcome to the board!
Had a feeling about that..Thanks
