Guys,
I need a little help.
I want to buy new inlet manifold boots.
These are the rubber boots connecting the manifold to the cylinders.
There are two of these. One for the front cylinder and of course one for the back.
What I like to know is: are front and back the same?
I ask this because I only find one part number: 1710-mem-670.
Thank you in advance
Thanks for your input Hans.
So your saying front and rear are the same and I should order two?
Only if you need them.
Defective?? Holes?? Cracks??
There is an o-ring that can be replaced.
#25 O-RING (39.5X2.6) 40mm x3mm should work
I bought o-rings for the exhaust port inspection cover from ACE hardware.
Well,
The rear one lets a little bit of false air pass. So I have to do something about this. I know the solution is probably easy but, I live in the trophics, and rubber parts dry out fast. So whenever if comes to rubber parts I like to have them at hand before starting the repair. And even if I don't need them immediatly, it is a good thing to have them in stock.
Thanks once again for your help!
