1 - 1 of 1 Posts
Ad-Ons since purchase:
1. Cobra Swept Front and rear Boards
2. Breakaway Throttle Lock
3. Progressive Front Springs
4. Wal-Mart Driving lights
5. Silverstar (sylvania) Headlamp
6. Hopnel W/Pouch tank bib
7. 12 volt power point
8. Mustang 2-up Touring seats
9. Kewl Metal Risers
10.
11.
12.
Purchased Feb-March of 2008 w/5,200 miles and not sure about previous maintenance.
Misc: Tightened battery cables and checked all grounds.
Added insulation on top and bottom of ECU to help reduce vibration/wires breaking.
Removed Helmet lock and added red loctite to bolts and re-installed.
Keep air pressure 38PSI front and 40PSI rear.
5,600 miles: Oil & Filter Change (10W-40 Valvoline MC oil and Honda Filter)
6,000 miles: Oil & Filter Change (10W-40 Valvoline MC oil and Bosch Filter)
6,000 miles: Serviced Differential (Valvoline 75W-90 Semi-Synthetic)
7,000 miles: Changed engine coolant & tighten all hoses (Honda Coolant)
7,000 miles: Adjusted Valves (only 2 out of adjustment) and removed the pair valve assembly.
7,000 miles: Changed out fork oil while doing springs. (used Honda Brand recommended fork oil)
7,000 miles: Replaced Spark Plugs (NGK/XU20EPR-U)
7,563 miles: Oil & Filter Change (10W-40 Valvoline MC oil and Bosch 3300 Filter)
10,550 miles:Oil & Filter Change (10W-40 Valvoline MC oil and Bosch 3323 Filter)
10,550 miles: Serviced Differential (Valvoline 75W-90 Semi-Synthetic)
10,550 miles: Replaced rubber grommet on exhaust shield (rear Cyl)
10,550 miles: Installed McMasterCarr bushings on both rear shocks.
Notes: Tires are original but seem to have plenty of life left in them. I have already purchased a new set of Metzlers (on sale DLP) so when the time comes I'm ready.
The bike came from the previous owner with the NC 2-up windshield, Honda line luggage rack & backrest, ISO grips.
1 - 1 of 1 Posts
