I've had my hyper charger on for almost two years now. I've never had a problem with it until recently. It seems that it hangs wide open all the time while running. Any ideas what may have gone wrong ? I'm thinking the diaphram went bad. I haven't changed anything to make this happen either. If it is the diaphram where should I go for a new one ? Kuryakyn ? Or does someone else have them ? Thanks.
Does it work at idle ? Check your vacuum line to make sure it is still good and not leaking kury is the only place i know of to get parts and they may refer you to a dealer not sure
At idle it is close to 3/4 of the way open.
It could be sticking on the filter, they operate pretty close.
I have seen 1 bad diaphram and 1 diaphram installed backwards from Kury. The easiest way to test is with a vacuum pump :wink: Also check the hose from the intake manifold as I've seen a few damaged from heat and engine cleaners
could be just warn out. they don't last forever and I have had friends have to replace the diaphram assembly.
it maybe just needs to be lubed with a spray or like said above vacuum leak.
John
