1 - 12 of 12 Posts
I have a yellow box on my 1800r to correct my speedo. With a GPS my speed is PERFECT right on. But, my odometer is about 8% slow. Does the odemeter and mph work on differant system? My gps shows 43mpg. Thanks Buzz
They are seperate. If you check the speedo healer instructions you will see you can set it to correct either one, but not both at the same time?? Seemed strange to me too??
after I put on my 200 Avon/170 my speedo came in line with my GPS.
okay, not knowing anything about the speedo healer, it begs the question, if I were to buy two speedo healers, could I correct both then?
Put a 1300 final drive on it and use the speedo healer to fix the odometer.
Already done that...was just curious if the speedo healer would correct both if you had two of them. The 1300 final takes it a little bit the other way, actually so it's still a bit off.
I'm sure it could be done, but not easily. THe healer simply plugs in, to use twon you would have to rewire it?? It actually partially corrects the odo when you correct the speedo. So it is fairly close. I think on my CBR I had to add 10% to get the speedo right, but only 8% to get the odo right? I added 9% and called it good.
1 - 12 of 12 Posts
