1 - 20 of 110 Posts
0 miles...12/03/03
* Bought bike brand new
2,958 miles...03/09/04
* Installed Kury Lightbar, Turn Signal Mirrors, ISO Grips, Throttle Boss & Stiletto end caps
~10,000 miles...02/27/05
* Installed Hard Krome K-2s, Thunder Tornado & DynoJet Stage 3 jet kit
11,300 miles...4/16/05
* Replaced stock Dunlops with Avon Venoms (1st set of Avons)
25,xxx miles
* Replaced rear tire (2nd Avon rear)
31,498 miles
* Replaced front tire (2nd Avon front)
40,691 miles...02/2007
* Installed chromed pieces from Handler & Airline Plating
* Broke down forks/reassembled
* Broke down front caliper & master cylinder/reassembled
* Changed front/rear brake fluid
* Changed throttle/clutch cables to Magnum Sterling Chromite
* Changed front brake line to Galfer SS
* Installed CP Punishers & ran wires internally
* Installed BrakeAway
Discussion Starter #14
62,057 miles...3/15/09
* The blocked PAIR hose was cracked, so I fixed it by cutting off the cracked end and putting a smaller diameter bolt with a zip tie
* Lubed/adjusted clutch cable
* Oil/Filter change
* Final drive fluid change
* Changed fork oil
* Changed coolant
* Installed Speed Bleeders & bled front/rear brakes with new brake fluid
* Installed rear brake pads
* Tore down carb & thoroughly cleaned/replaced the following:
_____ Accelerator pump components that were corroded (16021-KBG-670)
_____ Float chamber gasket (16163-MEA-671)
* Polished fins; painted engine, carb & manifold using DupliColor 500-Degree Semi-Gloss Black
* Performed valve adjustment
* Re-tapped lower rear exhaust stud hole in rear cylinder & installed new exhaust stud
* Purchased new acorn nuts and used anti-seize compound on all four nuts
* Used Eagle One Nevr-Dull Wadding Polish on the exhaust to clean them up really well
* Replaced the following o-rings/washers/gaskets:
_____1. Timing hole cap - 1 (91301-ML7-003)
_____2. Oil dipstick - 1 (91307-425-003)
_____3. Final drive fill cap - 1 (91302-001-020)
_____4. Final drive sealing washer - 1 (94109-14000)
_____5. Fork cap - 2 (91356-KF0-003)
_____6. Cylinder oblong tappet cover - 2 (12392-HC4-005)
_____7. Cylinder round tappet cover - 2 (91303-KK3-830)
_____8. Exhaust crush gaskets - 2 (18291-MR5-801)
All that is very inpressive, hope someday you can afford to paint your fairing.
1 - 20 of 110 Posts
