21 - 40 of 110 Posts
Discussion Starter #21
All that is very inpressive, hope someday you can afford to paint your fairing.
:lol: I finally have the funds, but I need to do a few more modifications to the fairing before it goes out for paint. But it shouldn't be too much longer now!
Discussion Starter #22
73,794 miles - 03/31/10
* New set of Avon Venoms (4th Avon front/5th Avon rear)
* Checked all wheel bearings & flange bearings
* Valve adjustment
* Installed painted fairing & stereo stuff
* Cleaned engine, carb & manifold thoroughly
Jason,
I can't believe you've only put 350 miles on your bike in the last 3 months - what up with that?
Looking forward to seeing the painted faring on your bike!!
Discussion Starter #24
Jason,
That makes two of us. It's been killing me not being able to ride, but I should be back in the saddle this coming week. My headlight trim ring broke, and I'm waiting on a replacement from a fellow Xer who is sending me his spare one...for just the cost of shipping! :cool:
Discussion Starter #25
74,124 miles - 4/24/10
* Rear brake pedal was sticking, so I tore down the pedal and lubed the shaft and rear caliper piston with white lithium grease
* Turn signal arm was loose - opened up switch housing and tightened down screw for the arm and placed a small amount of dielectric grease on the contact area
with all the stuff you are replacing you might as well have bought a HD...
:yikes:
J/k I hope my bike goes as long ans yours has!!!!
:bowdown:
Discussion Starter #29
:yikes:
:bowdown:
If you had painted it orange, it would have a better chance. :joke: The bike is looking good...can't wait to see it with all the other parts on it. :cool:
81,502 Miles - 1/1/2011
* Removed POS HK pipes and installed V&H Bigshots
I was wondering when you would pull them POS HKs off!! If I still have mine by summer mine will be gone to!
Discussion Starter #34
Discussion Starter #38
85,604 miles - 5/22/11
* Fairing repaired/repainted
* Possum pusher repainted
* Longboy front fender painted and installed
* Corbin backrest insert repainted
* Polished:
- Fender spacers
- Hardbag support arms
- Clutch perch/clamp
- Levers
- Glen's 2.5" headlight extension
- GPS mount
- Tank console bolt heads
- Hex coupler nuts for lightbar
- Lower tree cover made by Layzerdude
- Spacers for lower tree cover
- Clutch adjustment screw/stop screw
* Changed fork oil and put stock springs back in with 4.5" spacers
* Changed coolant
* Powder coated all inner fairing hardware, upper cable guides and the front brake caliper bracket
I will be over next week and you can do mine!!:smile:
Need a picture of your new goodies!!
