41 - 60 of 110 Posts
Really like that front fender!!
LOOKS GREAT!! :grin:
We should have a real good ride and party once you hit 100K miles on it. that is a hell of a lot of time in the saddle. I hope mine last as long, assuming I keep it that long.
Discussion Starter #45
88,904 Miles - 11/08/11
* Final drive oil change
* Changed brake fluid front & rear
* Installed new rear brake pads
* Installed new rubber boot on front master cylinder
* Cleaned spark plugs
* Mounted new Roadhouse Dooleys with shark fin tips
* Drilled kickstand and mounted carb spring bracket (credit to TennX) with chrome flat-head bolt, lock washer and acorn nut
* Changed out bubbled clutch & timing covers with used ones in good shape
Discussion Starter #55
92,497 Miles - 03/24/12
* Replaced rear tire (6th Avon rear) - 18,703 miles on 5th rear tire
* Replaced worn out dampers on the rear wheel
* Replaced worn out Flange A (bearing failure) with a reworked one from Jon's1800VTXC
* Replaced dead battery (lasted 6.5 years)
95,665 Miles - 09/19/12
* Cleaned/re-oiled Tornado filter
* Replaced crankcase breather filter
* Installed new Kury Stiletto front foot pegs & adapters, and changd out the stock "feelers" with titanium feelers
** Side note: Post #9,000 ** :mrgreen:
Nice. Now go get a life you post whore. Lol
