So I bought this 6 months ago for 500 dollars it had set in a back yard for over a year and wouldn't start, I cleaned the carb and put plugs in it and rode it until January then I put it on the stand and went to work I painted it myself I put new tires on it, the previous owner had kryloned everything black except the fender rails and the speedo cover on the tank, I stripped all of the krylon and restored chrome. I added a batwing fairing with stereo a set of Harley bags and a trunk, added a crash bar with highway pegs all new led lighting, wrapped the pipes and rejetted the carb, I removed the pair valve and added a Harley ignition switch on the tank and removed the switch under the seat, I added the clutch pull relief mod and the mixture cable so I don't have to remove the tank to adjust the carb. I changed all the fluids and adjusted the valves, there was alot more I can't even think of now, anyway today it came out for its first ride after over 2 months on the stand, here are some before during and after,
170791
170792
170795
170796
170797
170798
170799
170800
91112544_10221663519162488_6663875569173659648_o.jpg 70326539_10219790545699322_5311571860096286720_n (1).jpg 90879408_10221663495001884_4951211691506401280_o.jpg 90766720_10221663496801929_8576708820032552960_o.jpg 90672441_10221663504242115_6914090399514492928_o.jpg 91373333_10221663504722127_8811033057357201408_o.jpg 90958932_10221662757303442_6875924379524399104_o.jpg 91104225_10221662753343343_1169366212828725248_o.jpg 90776044_10221662696141913_4600329321737879552_o.jpg 91112544_10221663519162488_6663875569173659648_o.jpg 70326539_10219790545699322_5311571860096286720_n (1).jpg 90879408_10221663495001884_4951211691506401280_o.jpg 90766720_10221663496801929_8576708820032552960_o.jpg 90672441_10221663504242115_6914090399514492928_o.jpg 91373333_10221663504722127_8811033057357201408_o.jpg 90958932_10221662757303442_6875924379524399104_o.jpg 91104225_10221662753343343_1169366212828725248_o.jpg 90776044_10221662696141913_4600329321737879552_o.jpg
170801
170794
Great job! A quick question, what did you do for the flames?
I love it! Great job!
