Some background on the bike:
This is my weekly rider, so it hasn't sat. I keep the battery on a trickle charger, but the battery is about 5 yrs. old. Over the past few weeks I've noticed the bike taking more effort to start. It typically takes 2 tries, (hasn't started on the first try in years) but it's taken 3 of late. Last week it would crank, but after 6 attempts, the battery was drained and even the display lights went out.
Since the above:
Any advice before I slit my wrists?
Replace the regulator/rectifier (not that expensive) and see what happens? Need a new stator? Something I think I can do myself.
HELP!
Since the above:
- I purchased a new Yuasa High Performance (AGM) battery, hooked it up and after 2 tries the bike started.
- Next day, it cranked with no start five attempts, and then wouldn't crank. I put the battery back on the charger over night.
- Today battery cranked the bike over 4-5 attempts and then wouldn't crank, and ended with a rattling click sound.
- Lights work, horn honks, signals flash.
- Pulled air filter, it's clean.
- Pulled spark plug it's a little rich but still clean.
- I can visually see fuel spray into the carb when I twist the throttle.
- Checked wires in boot left side of bike for signs of short, none found.
- Hooked battery up to charger for 30 min. & checked charge with multimeter; Shows 13 amps.
- Used multimeter to check for parasitic draw; Shows .006-7 mA. Manual spec is less than 2 ma (2 milliamps or .002 amp).
HELP!
