1 - 9 of 9 Posts
· Super Moderator
Welcome to the board!
· Super Moderator
Pipes are well talked about on the board. If you want a slip-on style; Roadhouse seems to be the favorite. If you want a full system(headers&all);
1. Jardine Drags
2. Vance&Hines Bigshots
3. Muzzy 2into1 stainless
Be warned, these all may get the "pop" sound, it just does. But, there is an easy way to solve that by removing the pair valve system. This is a smog device, that injects fresh air into the exhaust ports to help burn off excess gases. Read these following links for how&why. 8)
http://www.rwmillerandsons.com/Riley/Ai ... mogmod.htm
Use block off plates found here;
http://www.hondadirectlineusa.com/vtx/p ... =340510562
See the valves&where the plates go here;
http://www.vtxoa.com/forums/viewtopic.p ... light=pair
1 - 9 of 9 Posts
