Performed the pair valve removal and demsog using Biglry's instruction. I am pretty sure I did everythng right, except I used two 1/2 inch oil hoses to plug off the reed valves, I checked and did not find any disconnected or pinched lines. The hoses were about 1-1/2 inch long, decided to use them while I am waiting on my GP block off plates to come in.
After completing the job, I started the engine and after it warms up I a I get a odd sound gurguling or something like that from the rear cylinder exhaust pipe. Also the exhaust gases from the rear cylinder pipe seem to lose some pressure and are much hotter than the front cylinder. I don't think the hoses are leaking I plugged them pretty well.
I took a ride today and was stuck in traffic, it was around 85-90 degrees out and it seems that the radiator fan kicked on more often than it normally does at this temperature.
Noticed the same thing when I got back from riding the rear cylinder exhaust gas pressure coming from the pipes seems to be a little hotter and less pressure than the front pipe.
I am running the stock air box, with HK 2-1/2 American straight pipes and a TFI fuel unit.
I was thinking the rear cylinder probably runs a little hotter and maybe the length of pipes or something to do with the pipes would cause the difference in pressure.
As I remember before I did the mod they both felt about the same.
Did I scr..... something up? Any ideas on what my mistake I have made or is this normal after the desmog/pair valve removal.
Need some help, please !!!! Don't want to get stuck on the road with an overheated
I didn't notice much difference in performance, just seems the fan is running more often. Most of the decel popping is gone and it seems that the jake brake effect is much less.
Is this something I should worry about? Appreciate any advice.
