1 - 3 of 3 Posts
I have a 2007 VTX 1800T and just recently when the bike is placed in neutral, the neutral light does not come immediately. Once it is in neutral the light comes on, but only if I let the clutch out slowly. I believe I have to either clean or replace the neutral switch. Does anyone know where it is located.
The neutral switch is located under the left side crankcase cover. The cover above the kickstand with 7? allen bolts. You might want to check to see if your linkage is binding. That is a common problem with the X and may be the cause of your issue. Not springing back where it should be. Re-lubing the pivot shaft at the shifter usually fixes things..............
Show
1 - 3 of 3 Posts
