1 - 10 of 10 Posts
Hi i bought a 1300S 2007 and want to know if you can point me in the right direction. I like the wide tire look but want to keep the spokes. I see alot on the 240 kit but nothing larger? is there a larger kit? I can handle the mods to the factory swing arm for the 240 but would like larger. I want to keep the rear fender look and ride 2up alot. I would like an air suspension. and to increase the rake on the forks. cobra long pipes. and lots of chrome. polished fins.
can i get a wider spoke wheel or is there some where you might recomend to change mine up.
300 kit?
anyone with the 240 on a S/R model with the S/R fender?
Clocking the front fender after tripple tree and extended forks to keep hings lined up.
good seat for 2up riding some recomendations please
Trenton
Yes you can get a wider laced wheel done for you
Not really a kit as not just the swingarm needs mods, you need a second u-joint in there to get the driveshaft around the wheel
The stock fender will not fit around the 240 wheel
Trenton
If you go with a 240 kit or above, you will be severely limited for seats. You will have to get teh seat that is made for the fender kit you choose. If you do a lot of 2-up and stay with the stock fenders, you should try Ultimate Seats.
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
well you can sqeeze a 250 with some mods on the 240 kit.as far as the rest goes,I went rigid so the fender hugs the tire,I didn't want that 1 1/2 gap between the tire and fender.sumo-x kit offers 1.5 seat. good luck on whatever you choose.
:agree: Sumo-X, I Love that Retro fender
Not really a kit as not just the swingarm needs mods said:
i like the look of a fat too but - how much horsepower is dropped via the mods? also - there is more to maintain.fail.....
bags
I may be talking too soon but i have some bags and removable “ghost brackets” I haven’t used in some time. I may be willing to part with them. let me know if there is any interest.
I'm pushing right at about 67 HP with a 240 and can spin the 240 thru 1st in to second. Can't really say I lost HP. As for as maintenance, the tire cost more to replace and you have to pull the final drive to remove the rear wheel.
1 - 10 of 10 Posts
