lights
Have you had your head light open there may be a ground wire or hot wire unpluged . or have you had your seat off there a lot of wires under there and the side cover that may have came louse . Good luck
Check grounding
I would have to say check the ground as well. I think some of the VTXs had grounding problems. Search that and you might find an easy fix on this site.
Curtis
kannibul said:
gunnie314 said:
hello
on my 1300 I have no headlight or running light. Fuses are ok.....
Any help is appreciated. Thanks :?:
Nothing at all?
Blinkers, high beams?
I'd say to check your ground.
Does the bike start?[/quote
thanks you kannibul for your reply, it starts, runs, backlight works,turn signal works, just not the headlights, there is no power to the head light..
