Hi, bought a 05 1300c. Was a few counties away so the price was right and I bought it. No known mods or history . 22k miles. First, I rode over to the gas station as the fuel was on reserve. Pops and idling poorly. Had to rev to cross the street.
Filled tank, spent most of today chasing wires to get the rear turn sigs working. It had some kind of Humpty Dumpty electronic who knows what wired in to the rear lights but disconnected from its power source. Removed it and lights are working.
Put everything back together and started up. 6 second crank, choke needed, as soon as I pushed the choke in it idled nice, not so nice, not at all.
I have to rev to keep it going even after 4 or 5 minutes. Holding the throttle at just enough twist to keep it running, maybe 12, 1300 rpm I can hear popping out the back. Irratic and a bit out the carb.
SO......Gas ? maybe got so low something got sucked up? Adjustments? how do they get out of adjustment in the first place. Ca smog causing problems? could be.
I put a Subaru engine in a VW and the only problems I had were Ca smog items.
Any thoughts on where to start here? Preferably easiest most likely first. If I need to remove and disassemble, what gaskets or items are required to replace.
Thanks for any info,
C
C
