21 - 24 of 24 Posts
If the neutral position dash light fails to show green when in neutral gear and nothing happens when starter switch is pushed then check on the neutral safety switch...down on left side of transmission body housing.. Had one fail due to wearing down physical length.. Had to show the dealer on his computer a picture of the part that they claimed did not exist...... Bike could be pushed started but was a back breaker if you did not have another body or two to help push. Hope this might help someone in the future ...........................
Reactions: rangers4u
Discussion Starter · #23 ·
I had this happen and it ended being the key switch, the connection inside the switch got loose and vibration from the motor would make it cut out
How do you get the key switch apart to look it over ? I gave a quick look and didn't see any screws to loosen to take it off .
21 - 24 of 24 Posts
