Hey guys hope you can help
Did my first oil & filter change yesterday all went well but now when I hit the starter the bike sounds different it seams to run on a bit sort of whining then disappears and runs great checked levels all ok
did I stuff something up?:confused:
Carl
Hello Carl, welcome to the VTXOA.
Run on - Starter switch releasing when you remove thumb?
Rare to have a 1300 with a sticking starter relay.
You maybe listening more intently than you did before.
Did you use a 10-40 or something else?
May just be the oil difference on the sprag clutch.
Part #5 http://www.partzilla.com/parts/search/Honda/Motorcycle/2005/VTX1300R+A/ALTERNATOR/parts.html
http://cdn.partzilla.com/product/oem/pz/a/1/7/a17fbbcd10265d7f1b93b067a4f95ff9.jpg
Starter switch cleaning:: http://www.rattlebars.com/mtz/starter.html
Hey Mate thanks for the reply put Motul 10-40 fully synthetic in it,
the switch seams ok I just haven't noticed it before it just is a sort of wurring noise
When the button is released
I was a bit worried I might have drained something I shouldn't of when I undid the front drain plug
Thanks heaps for the info
Regards
Carl
Sent from my iPad using Tapatalk
Front drain plug is for the crankcase - dry sump.
Scavenge half of the oil pump sucks that up.
Not much oil from there, primarily what drips down after shutdown.
Welcome to the VTXOA from the southeast corner of NC.
